This command specifies that RIP routes are exported into BGP.
| aspath-limit limit | (Optional) Specifies the upper limit on AS-path length. Valid values are 0 - 255. Default value is 1. |
| origin code | (Optional) Specifies the origin process attribute. Valid values are: 0 - IGP 1 - EGP 2 - Incomplete Default value is 2. |
| med value | (Optional) Specifies the multi-exit discriminator value for this route. Valid values are 0 - 4294967295. Default value is 0. |
| local-pref value | (Optional) Specifies a route selection value for this route when the same prefix is learned from multiple peers. |
| route-map name | (Optional) A route-map name to apply to these routes. |
BGP Router Configuration or BGP address family configuration mode.
The redistribute rip command provides for the exporting of RIP routes into BGP.
The no redistribute rip command removes redistribution of RIP route configuration from the router.
In the following example BGP is configured to redistribute all RIP routes with the local preference set for 100.
System(su-config)->router bgp 65151 System(su-config-bgp)->redistribute rip local-pref 100
Print
this page
Email this topic
Feedback
