Use this command to set the amount of time required to transmit a link state update packet on an interface.
| seconds | Specifies the transmit delay in seconds. Valid values are from 1 to 65535. Default: 1 Second. |
None.
OSPF router configuration.
The “no” form of this command resets the transmit delay value to the default.
This example shows how to set the time required to transmit a link state update packet on VLAN 1 at 20 seconds:
System(rw-config)->interface vlan 1 System(rw-config-intf-vlan.0.1)->ip ospf transmit-delay 20
Print
this page
Email this topic
Feedback
