Use this command to clear the TCP connection to an MSDP peer and reset all MSDP message counters.
| peer-address | (Optional) Specifies the IP address of the MSDP peer to which the TCP connection is to be cleared. |
All MSDP peers are cleared.
Global configuration mode.
If this command is run without the peer-address parameter, all MSDP peers are cleared.
This example shows how to clear the connection to MSDP peer 192.168.30.20:
System(su-config)->clear ip msdp peer 192.168.30.20
Print
this page
Email this topic
Feedback
