Use this command to set a Class of Service inbound rate limiting reference configuration.
| group-type-index | Specifies an inbound rate limiting port group-type index for this entry. Valid entries are in the form of group.type. Group can be 0 - 11, with 0 designating the default group, and 1 - 11 reserved for user-defined groups. Port type can be 0 - 1 for the S- and K-Series and 0 for the 7100-Series. |
| reference | Specifies a reference number to be associated with this entry. |
| rate-limit number | Specifies a rate limiter resource ID to bind to this entry. |
None.
All command modes.
This S- and K-Series example shows how to configure inbound rate limiting reference entry 0 for port group 0.1 referencing resources defined by IRL entry 0:
System(rw)->set cos reference irl 0.1 0 rate-limit 0
This 7100-Series example shows how to configure inbound rate limiting reference entry 0 for port group 0.0 referencing resources defined by IRL entry 0:
System(rw)->set cos reference irl 0.0 0 rate-limit 0
Print
this page
Email this topic
Feedback
