This command configures the remote AS for the specified peer.
| ip-address | Specifies a BGP peer as a valid IPv4 address in dotted-quad format or as a valid IPv6 address in colon-separated format. |
| as-num | Specifies the autonomous system (AS) number of the specified BGP peer. Valid values are 1 - 4294967295. |
| password password | (Optional) Specifies an MD5 password for this peer. Valid values are up to 128 characters. |
None.
BGP Router Configuration.
The neighbor remote-as command configures the AS of the specified peer.
The no neighbor remote-as command removes the AS configuration for the specified peer.
This example configures a BGP peer 1.2.3.4 with an AS number of 5:
System(su-config)->router bgp 65151 System(su-config-bgp)->bgp router-id 159.1.1.9 System(su-config-bgp)->neighbor 1.2.3.4 remote-as 5
The following example configures a IPv6 BGP peer address with an AS number of 64600:
router(config)->router bgp 65000 router(config-router-bgp)->bgp router-id 159.1.1.9 router(config-router-bgp)->neighbor 2001:0DB8:0:CC00::1 remote-as 64600
Print
this page
Email this topic
Feedback
