Use this command to clear OAM counters or reset OAM configuration to default values for the specified port(s).
| port-string | Specifies the port(s) to reset the OAM configuration to default values for. For a detailed description of possible port-string values, refer to Port String Syntax Used in the CLI in the S-, K-, and 7100 Series Configuration Guide. |
| all | Resets all OAM configuration to the default values for the specified port(s). |
| status | Resets OAM status for the specified port(s) to the default value of disabled. |
| mode | Resets the operating mode for the OAM client to the default value of active for the specified port(s). |
| loopback-rx | Resets the OAM loopback mode to the default value of ignore for the specified port(s) (S-, K-Series). |
| remote-loopback | Resets the OAM remote loopback to the default value of disable for the specified port(s) (S-, K-Series). |
| notify-retry | Resets the number of OAM notify retries to send for the specified port(s) to the default value of 0. |
None.
All command modes.
The loopback-rx and remote-loopback options are supported on the S- and K-Series platforms.
This example shows how to reset the OAM operating mode for the OAM client to the default value of active for port ge.1.3:
System(rw)->clear port oam ge.1.3 mode System(rw)->
Print
this page
Email this topic
Feedback
