Use this command to enable or disable BFD echo-mode for this BDF session.
None.
BFD echo-mode is enabled by default.
BFD probe configuration mode.
Use the “no” option to disable echo mode.
This example shows how to disable the Echo function for BFD session bfdProbe1:
System(rw)->configure System(rw-config)->probe bfdProbe1 bfd System(su-config-probe-bfd)->no echo-mode System(su-config-probe-bfd)->
Print
this page
Email this topic
Feedback
