Sets the amount of time that will expire before this VRRP instance takes control from the current master when preemption is enable.
| vrid | Specifies the VRRP instance to which the delay will be applied. |
| delay | Specifies the delay in seconds before this VRID takes control from the current master. Valid Values: 1 - 900 seconds. |
None.
Interface configuration mode.
The router that owns the virtual router IP address always preempts other routers, regardless of this setting.
When preempt mode is enabled this specifies a delay (in seconds) that a higher priority backup router must wait to preempt a lower priority master. For more information on setting preempt status, refer back to vrrp preempt. For more information on setting VRRP priority, refer back to vrrp priority.
The “no” form of this command clears the preempt delay timer.
This example sets the preempt-delay timer to 60 seconds for VRRP instance 1:
System(rw)-> System(rw)->configure System(rw-config)->interface vlan 20 System(rw-config-intf-vlan.0.20)->vrrp preempt-delay 1 60 System(rw-config-intf-vlan.0.20)->
Print
this page
Email this topic
Feedback
