Use this command to clear congestion notification configuration for the specified priority and context.
| port-name | Specifies the port for the CNPV to be cleared. |
| priority | Specifies the CNPV to be cleared for the specified context. |
| choice | Resets the domain defense choice to the default of auto on the specified port. |
| alt-pri | Resets the alternate priority on the specified port for the specified CNPV to the default of next lowest non-CNPV priority value or next highest non-CNPV value if all lower values are CNPV, if global defense choice is set to auto. If global defense choice is set to admin, the alternate priority defaults to 0. |
| defense | Resets the domain defense method on the specified port for the specified CNPV to the default value of:
| lldp | Resets the congestion notification LLDP state on the specified port to the default value of enabled. |
None.
All command modes.
This example deletes congestion notification entry CNPV 3 on port tg.1.1:
System(rw)->clear dcb cn port-priority tg.1.1 3 entry
Print
this page
Email this topic
Feedback
