Use this command to set the number of seconds of idle time to elapse before a binding will be deleted for both an IPv4 or IPv6 virtual server configuration.
| timeperiod | Specifies the time (in seconds) after which an idle binding connection between clients and the virtual server will be removed. Default value = 240 seconds. |
240 seconds.
Configuration command, SLB Virtual Server Configuration mode.
The “no” form of this command resets the timeout to the default of 240 seconds.
This example shows how to set the non-sticky session idle timeout to 360 seconds on the virtual server named “virtual-http”:
System(rw-config)->ip slb vserver virtual-http System (rw-config-slb-vserver)->serverfarm myproductHTTP System (rw-config-slb-vserver)->virtual 10.1.4.5 tcp www System (rw-config-slb-vserver)->idle timeout 360 System (rw-config-slb-vserver)->inservice
This example shows how to set the non-sticky session idle timeout to 360 seconds on the virtual server named “virtual-http66”:
System(rw-config)->ipv6 slb vserver virtual-http66 System (rw-config-slb-vserver)->serverfarm myproductHTTP66 System (rw-config-slb-vserver)->virtual 2001:11ac:fd34::5 udp tftp System (rw-config-slb-vserver)->idle timeout 360 System (rw-config-slb-vserver)->inservice
Print
this page
Email this topic
Feedback
