Use this command to match a route metric or range of route metrics.
| cost | Specifies a metric cost to be matched for this route-map. Valid values: 1 - 4294967295. Default Value: None. |
| range min-cost max-cost | Specifies a range of metric costs to be matched for this route-map:
None.
Route-map configuration.
The “no” form of this command removes the match for the specified cost or range of costs.
This example shows how to match a range of costs starting at 100 and ending at 200 for redistribution route-map rm5:
System(rw-config)->route-map redistribution rm5 System(rw--config-route-map)->match metric range 100 200 System(rw--config-route-map)->
Print
this page
Email this topic
Feedback
