Use this command to increment the existing cost when redistributing a source packet matched by this route-map.
| cost | Specifies the amount to increment the existing cost when redistributing a source packet matched by this route-map. Valid values: 1 - 4294967295. Default Value: None. |
None.
Route-map configuration.
The “no” form of this command deletes this metric increment set clause.
This example shows how to increment the route cost by 50 when redistributing source packets matched in the rm5 route-map:
System(rw-config)->route-map redistribution rm5 System(rw-config-route-map)->set metric increment 50 System(rw-config-route-map)->
Print
this page
Email this topic
Feedback
