Use this command to prevent RIP from transmitting update packets on an interface.
| vlan vlan-id | Specifies the number of the VLAN to make a passive interface. This VLAN must be configured for IP routing. |
None.
RIP configuration command mode.
This command does not prevent RIP from monitoring updates on the interface.
The “no” form of this command disables passive interface.
This example shows how to set VLAN 2 as a passive interface. No RIP updates will be transmitted on VLAN 2:
System(rw-config)->router rip System(rw-config-rip)->passive-interface vlan 2
Print
this page
Email this topic
Feedback
