Use this command to configure the maximum number of parallel routes to be installed into the routing table for this device.
| num | Specifies the maximum number of paths to be installed into the routing table for this device. Valid values are 1 - 32 routes. The default value is 8 routes. |
None.
IS-IS router configuration.
The “no” form of this command resets the maximum number of parallel routes to be installed into the routing table to the default value of 8 routes.
This example shows how to configure the maximum number of parallel routes installable in the routing table to 12:
System(rw)->configure System(rw-config)->router isis System(rw-config-isis)->maximum-paths 12 System(rw-config-isis)->
Print
this page
Email this topic
Feedback
