Use this command to specify the Any-Source Multicast groups permitted to cross this interface in either an inbound or outbound direction.
standard-acl | Specifies the standard ACL containing ASM group permit or deny entries. |
None.
Interface command mode.
The ASM join filter applies a standard permit/deny ACL that defines which Any-Source Multicast groups are permitted to cross this interface either inbound our outbound.
The “no” form of this command removes the specified ASM join filter.
This example defines the ASM groups permitted to cross this interface using the asmFilter1 standard ACL on VLAN 100:
System(su-config)->interface vlan 100 System(su-config-intf-vlan.0.100)->ip pim asm-join-filter asmFilter1 System(su-config-intf-vlan.0.1)->
