Use this command to enable or disable a RIP authentication key chain for use on an interface.
| name | Specifies the key chain name to enable or disable for RIP authentication. |
None.
Interface configuration command mode.
Both a RIP authentication keychain must be enabled and the RIP authentication mode () must be configured before authentication will be active.
The “no” form of this command prevents RIP from using authentication.
This example shows how to set the RIP authentication key chain to “password” on VLAN 1:
System(rw-config)->interface vlan 1 System(rw-config-intf-vlan.0.1)->ip rip authentication keychain password
Print
this page
Email this topic
Feedback
