Use this command to clear the properties set for one or more console ports to its default value.
| baud | Clears the input/output baud rate. |
| bits | Clears the number of bits per character. |
| cts-link | Sets CTS link detection to the default value of enabled. |
| flowcontrol | Clears the type of flow control. |
| parity | Clears the type of parity. |
| stopbits | Clears the number of stop bits. |
| vt100 | Clears the Device Status Request (DSR) status for the VT100 console. |
| port-string | (Optional) Clears properties for specific console port(s). |
If no property is specified, all property values are reset to the default value. If port-string is not specified, all or the specified property for all console ports will be cleared.
All command modes.
If C2 security mode is enabled, You can not clear a console configuration while in Read-Write user mode.
This example shows how to clear the baud rate on console port com.1.1:
System(rw)->clear console baud com.1.1
This example shows how to clear the bits property on all console ports:
System(rw)->clear console bits
This example shows how to clear the flowcontrol property value console port com.1.1:
System(rw)->clear console flowcontrol com.1.1
This example shows how to clear the parity property value on all ports:
System(rw)->clear console parity
This example shows how to clear the stopbits property value on console ports com.1.1 and com.1.2:
System(rw)->clear console stopbits one com.1.1-2show console
Print
this page
Email this topic
Feedback
