Use this command to configure a two device network that uses broadcast media and IS-IS to function as a point-to-point link.
None.
None.
Interface configuration.
This command configures the interface to be part of a two device network that uses broadcast media and IS-IS routing to function as a point-to-point link instead of a broadcast link. Network point-to-point mode causes the system to issue packets point-to-point rather than as broadcasts for the interface.
The “no” form of this command disables network point-to-point functionality on the interface.
This example shows how to enable VLAN 100 for network point-to-point:
System(rw)->configure System(rw-config)->interface vlan 100 System(rw-config-intf-vlan.0.100)->isis network-point-to-point System(rw-config-intf-vlan.0.100)->
Print
this page
Email this topic
Feedback
