Use this command to create a tracked object and enter tracked object configuration mode.
| track-name | Specifies the name of the tracked object. Value is a character string from 1 to 31 characters long. |
| port-group | Specifies that the tracked object is a port group type of tracked object. |
None.
Global configuration.
The port group tracked object allows you to monitor the line protocol status of a group of ports. After you execute this command, you enter tracked object configuration mode where you can further configure the tracked object.
The no form of the command deletes the tracked object from the Tracked Object Manager.
This example creates the port group tracked object named ls_group and enters tracked object configuration mode.
System(su)->configure System(su-config)->track ls_group port-group System(su-config-track-obj)->
Print
this page
Email this topic
Feedback
