Use this command to apply a cache weight value to IPv4 or IPv6 cache servers in a web cache server farm.
| weight | Specifies the weight assigned to an IPv4 or IPv6 cache server. Valid value range of 1-155. Default: 1. |
The cache server weight defaults to 1.
Configuration command, Cache Server Configuration mode.
The weight value only applies to caches being balanced via the round robin predictor type as described in predictor.
Weighted round robin is a round robin algorithm that takes into account a weight assigned to each cache server. Weight is a way of accounting for the resource differences between servers. If a server has the capacity to handle twice the number of sessions as another server, its weight ratio to the other server can be set to 2:1. The default weight for all cache servers is 1. When all cache servers are configured with the default weight, each cache server is treated equally. When a non-default weight is applied to any cache servers in the web cache server farm, the algorithm takes that weight into account when assigning sessions to the cache servers.
Consider the following example. A server farm contains three cache servers with the following weights: server A has a weight of 1, server B has a weight of 2, and server C has a weight of 3. For each six (the sum of the three weights) active sessions, server A will be assigned 1 session, server B will be assigned 2 sessions, and server C will be assigned 3 sessions in a round robin fashion. For this example, the weight ratio between the three servers would be 1:2:3.
This example configures the cache server 186.89.10.51 on the s1Server server farm with a weight of 2:
System(rw-config)->ip twcb wcserverfarm s1Server System(rw-config-twcb-wcsfarm)->cache 186.89.10.51 System(rw-config-twcb-cache)->weight 2 System(rw-config-twcb-cache)->
This example configures the cache server 2001:abcd::5 on the s2Server server farm with a weight of 3:
System(rw-config)->ip twcb wcserverfarm s2Server System(rw-config-twcb-wcsfarm)->cache 2001:abcd::5 System(rw-config-twcb-cache)->weight 3 System(rw-config-twcb-cache)->
Print
this page
Email this topic
Feedback
