Use this command to set a Class of Service transmit queue reference configuration.
group-type-index | Specifies a transmit queue port group-type index for this entry. Valid entries are in the form of group.type. Group can be 0 - 11, with 0 designating the default group, and 1 - 11 reserved for user-defined groups. Port type can be 0 - 1. |
reference | Specifies a reference number to be associated with this entry. |
queue number | Specifies a transmit queue resource ID to bind to this entry. |
None.
All command modes.
This example shows how to configure transmit queue reference resource entry 0 for port group 0.1 referencing resources defined by TXQ entry 0:
System(rw)->set cos reference txq 0.1 0 queue 0
