Use this command to configure LLDP-MED location information on a port or range of ports. Currently, only Emergency Call Services (ECS) Emergency Location Identification Number (ELIN) is supported.
| elin | Specifies that the ECS ELIN data format is to be used. |
| value | Specifies the location identifier. Value can be from 10 to 25 numerical characters. |
| port-string | Specifies the port or range of ports to be affected. |
None.
All command modes.
The Emergency Location Identification Number (ELIN) is a valid North America Numbering Plan format telephone number, supplied to the Public Safety Answering Point (PSAP) for Emergency Call System (ECS) purposes.
After you configure a location information value, you must also configure the port to send the Location Information TLV with the command.
This example configures the ELIN identifier 5551234567 on ports ge.1.1 through ge.1.6 and then configures the ports to send the Location Information TLV.
System(rw)->set lldp port location-info 5551234567 ge.1.1-6 System(rw)->set lldp port tx-tlv med-loc ge.1.1-6
Print
this page
Email this topic
Feedback
