Use this command to remove an Application Priority entry for the specified protocol and ID.
| port-string | Specifies the port to clear the Application Priority setting for. |
| protocol ethertype | tcp | udp | l4port | Specifies the protocol of the Application Priority to clear:
| protocol-id protocol-id | Specifies the ID of the protocol to be cleared. Valid values are from 0 - 65535 depending upon the protocol specified. |
None.
All command modes.
This example shows how to clear the Application Priority entry for the UDP service type dpkeyserv on port 1780:
System(rw)->clear dcb appPri tg.1.1 protocol udp protocol-id 1780
Print
this page
Email this topic
Feedback
