Use this command to clear one or all Class of Service inbound rate limiting port resource configurations.
| all | group-type-index | Clears all inbound rate limiting port resource entries or a specific entry. Valid group-type entries are in the form of group.type. Group can be 0 - 11, with 0 designating the default group, and 1 - 11 reserved for user-defined groups. Port type can be 0 - 1 for the S- and K-Series and 0 for the 7100-Series. |
| resource | Specifies a single or range of resource entries to be cleared. |
| unit | (Optional) Clears the unit of measure setting. |
| rate | (Optional) Clears the data rate setting. |
| type | (Optional) Clears the type of action setting. |
| syslog | (Optional) Clears the Syslog setting (S-, K-Series). |
| trap | (Optional) Clears the SNMP trap setting (S-, K-Series). |
| disable-port | (Optional) Clears the disable port setting (S-, K-Series). |
| violators port-list | (Optional) Clears the limit violation setting (S-, K-Series). |
If no options are specified, all non-default settings will be cleared for the associated rate limiter.
All command modes.
This S- and K-Series example shows how to clear all inbound rate limiting settings associated with port group 0.1, resource entry 0:
System(rw)->clear cos port-resource irl 0.1 0
This 7100-Series example shows how to clear all inbound rate limiting settings associated with port group 0.0, resource entry 0:
System(rw)->clear cos port-resource irl 0.0 0
Print
this page
Email this topic
Feedback
