Use this command to configure a mesh group of MSDP peers.
| mesh-group group-name | Specifies the name of the mesh group to which you are adding (or removing) MSDP peers. |
| peer-address | Specifies the IP address of the MSDP peer which belongs to that mesh group. |
None.
Global configuration mode.
An MSDP mesh group consists of a group of MSDP peers which have fully meshed MSDP connectivity between each other. By default, MSDP peers do not belong to a mesh group. Execute this command once for each MSDP peer in the group.
Use the “no” form of this command to remove a peer from the group.
This example shows how to add MSDP peer 192.168.30.20 to mesh group angel:
System(su-config)->ip msdp mesh-group angel 192.168.30.20
Print
this page
Email this topic
Feedback
