Use this command to set the firmware image the switch loads at startup or when performing a standard or an S-Series or 7100-Series high availability firmware upgrade (HAU).
| filename | Specifies the name of the firmware image file. |
| standard | (Optional) Specifies that the next system reset will result in a standard (non-HAU) upgrade. The entire system will be reset and all modules will load the new image. |
| high-availability | (Optional) Specifies that the next system reset will attempt to initiate a High-Availability upgrade. If all HAU preconditions are not met, the upgrade will not be performed. See the usage section below for HAU precondition details (S-, 7100-Series). |
On the K-Series, if the standard option is not specified, a standard upgrade is performed.
On the S- and 7100-Series, if no option is specified, the upgrade method for the new firmware image is determined by the default mode setting using set boot high-availability default-mode (S-, 7100-Series). The HAU default mode defaults to never which is the same as specifying the standard system boot method.
All command modes.
On the S- and 7100-Series, there are two methods for loading a system firmware image:
Setting a system boot method over-rides the HAU default mode set using set boot high-availability default-mode (S-, 7100-Series).
Using the standard method, the image is loaded automatically after the system has been reset. Although it is not necessary to choose to reset the system and activate the new boot image immediately, the CLI will prompt you whether or not you want to do so. You can choose “Yes” at the question prompt to have the system reset and load the new boot image immediately, or choose “No” to load the new boot image at a later scheduled time, by issuing one of the following commands: clear config, reset, or configure. The new boot setting will be remembered through resets and power downs, and will not take effect until the clear config, reset, or configure command is given.
On the S- and 7100-Series, the high availability upgrade method provides for loading new system firmware without resetting the entire system at once. HAU groups made up of one or more slots are upgraded one HAU group at a time rather than simultaneously. This process of staggering slot upgrades allows slots that do not belong to the HAU group that is currently being upgraded to continue normal operation, providing a high-degree of system availability during the upgrade process.
During a high availability upgrade each group slot will be temporarily unavailable while it is being upgraded, causing every physical port to experience an interruption during the upgrade process. These interruptions can be mitigated by a redundant network architecture, using Link Aggregation Groups (LAG) which span multiple slots. A properly configured LAG can continue to operate even when one or more of its component links are temporarily unavailable.
The following preconditions must be met for a high availability upgrade to occur:
If any of these preconditions are not met when attempting a high availability upgrade, no upgrade takes place. Should you wish a standard upgrade to automatically take place when an HAU precondition is not met:
This example shows how to set the boot firmware image file to “newimage” and reset the system with the new image loaded immediately using the standard method:
System(rw)->set boot system newimage standard This command can optionally reset the system to boot the new image. Do you want to reset now (y/n) [n]?y
Resetting system ...
This example, on an S- or 7100-Series, shows how to set the boot firmware image file to “haimage” and to immediately start the HA Upgrade:
System(rw)->set boot system haimage high-availability This command can optionally start a High-Availability Upgrade. Do you want to do this now (y/n) [n]?y Starting High-Availability Upgrade ...
This S- and 7100-Series example shows how to set the boot firmware image file to “haimage” and set the high availability upgrade to pending. The reset system command starts the high availability upgrade:
System(rw)->set boot system haimage high-availability This command can optionally start a High-Availability Upgrade. Do you want to do this now (y/n) [n]?n High-Availability Upgrade has been enabled and is now pending. The next system reset will start the upgrade. System(rw)-> System(rw)->reset system A High-Availability Upgrade is pending. If you proceed then the upgrade will start now and modules will be reset sequentially. Your CLI session will be disconnected sometime during this upgrade. Do you want to continue (y/n) [n]?y Starting High-Availability Upgrade ...
Print
this page
Email this topic
Feedback
