Use this command to clear the optional LLDP and LLDP-MED TLVs to be transmitted in LLDPDUs by the specified port or ports to the default value of disabled.
| all | Disables all optional TLVs from being transmitted in LLDPDUs. |
| port-desc | Disables the Port Description optional basic LLDP TLV from being transmitted in LLDPDUs. |
| sys-name | Disables the System Name optional basic LLDP TLV from being transmitted in LLDPDUs. |
| sys-desc | Disables the System Description optional basic LLDP TLV from being transmitted in LLDPDUs. |
| sys-cap | Disables the System Capabilities optional basic LLDP TLV from being transmitted in LLDPDUs. |
| mgmt-addr | Disables the Management Address optional basic LLDP TLV from being transmitted in LLDPDUs. |
| vlan-id | Disables the Port VLAN ID IEEE 802.1 Extensions TLV from being transmitted in LLDPDUs. |
| stp | Disables the Spanning Tree information defined by Protocol Identity IEEE 802.1 Extensions TLV from being transmitted in LLDPDUs. |
| lacp | Disables the LACP information defined by Protocol Identity IEEE 802.1 Extensions TLV from being transmitted in LLDPDUs. |
| gvrp | Disables the GVRP information defined by Protocol Identity IEEE 802.1 Extensions TLV from being transmitted in LLDPDUs. |
| mac-phy | Disables the MAC-PHY Configuration/Status IEEE 802.3 Extensions TLV from being transmitted in LLDPDUs. |
| poe | Disables the Power via MDI IEEE 802.3 Extensions TLV from being transmitted in LLDPDUs. Only valid for PoE-enabled ports. |
| link-aggr | Disables the Link Aggregation IEEE 802.3 Extensions TLV from being transmitted in LLDPDUs. |
| max-frame | Disables the Maximum Frame Size IEEE 802.3 Extensions TLV from being transmitted in LLDPDUs. |
| med-cap | Disables the LLDP-MED Capabilities TLV from being transmitted in LLDPDUs. |
| med-pol | Disables the LLDP-MED Network Policy TLV from being transmitted in LLDPDUs. |
| med-loc | Disables the LLDP-MED Location Identification TLV from being transmitted in LLDPDUs. |
| med-poe | Disables the LLDP-MED Extended Power via MDI TLV from being transmitted in LLDPDUs. Only valid for PoE-enabled ports. |
| enhanced-trans- config | Disables Enhanced Transmission Selection Configuration TLV on the specified port. |
| enhanced-trans-rec | Disables Enhanced Transmission Selection Recommendation TLV on the specified port. |
| priority-flowctrl | Disables the advertisement of priority flow control on the specified port. |
| application-pri | Disables the advertisement of application priority on the specified port. |
| congestion-notif | Disables the advertisement of congestion notification on the specified port. |
| port-string | Specifies the port or range of ports to be affected. |
None.
All command modes.
This example disables the management address, MED capability, MED network policy, and MED location identification TLVs from being sent in LLDPDUs by port ge.1.1.
System(rw)->clear lldp port tx-tlv mgmt-addr med-cap med-pol med-loc ge.1.1
Print
this page
Email this topic
Feedback
