Use this command to reset the PoE usage threshold on a specified module to the default value of 75 percent.
| module-number | Specifies the module on which to reset the PoE threshold. If you are clearing the threshold value on an S-Series SSA, use 1 as the module number. |
None.
All command modes.
This example shows how to reset the PoE threshold to 75 on module 1:
System(rw)->clear inlinepower threshold 1
Print
this page
Email this topic
Feedback
