Use this command to assign the tunnel to a Split Horizon group.
group-id | Specifies the Split Horizon group the tunnel is assigned to. Valid values are 1 - 62 (S-Series) and 1 - 16 (K-Series). |
None.
Tunnel Interface Configuration command mode.
Use the “no” option for this command to remove the tunnel from the Split Horizon group.
This example shows how to set the Split Horizon group to 1 for tunnel 1:
System(rw)->configure System(rw-config)->interface tunnel 1 System(rw-config-intf-tun.0.1)->tunnel split-horizon-group 1 System(rw-config-intf-tun.0.1)->
