Use this command to set the threshold for sending CPU utilization notification messages.
| threshold | Specifies a threshold value (in 1/10 of a percent).Valid range is 0–1000. A value of 0 will disable utilization notification messages. Default value: 800 (80%). |
None.
All command modes.
The value range is 0–1000 and represents the percentage of system utilization to use as the trap threshold.
This example shows how to set the system utilization threshold to 90%:
System(rw)->set system utilization threshold 900
Print
this page
Email this topic
Feedback
