Use this command to indicate whether the restore point will be applied when the system reboots.
| index | The index number of the restore point. Use the show config restore-point command to view the index number. |
| none | (Optional) Indicates that the restore point will not be applied when the system reboots. |
None.
All command modes.
If the restore point is applied when the system reboots, any configuration changes made after the restore point was set will be lost.
This command is not allowed if an HA upgrade is pending (S-, 7100-Series).
This examples shows how to not apply restore point 1245935343 when the system reboots:
System(rw)-> configure restore-point 1245935343 none
Print
this page
Email this topic
Feedback
