Use this command to enter Maintenance End-Point (MEP) Configuration mode for the specified end-point.
| mep-id | Specifies an ID for the MEP. Valid values are 1 - 8191. |
None.
Maintenance Association Configuration mode.
A maintenance association end-point (MEP) resides at the edge of an MD. A MEP is associated with a single MA that monitors a single VLAN. The MEP must belong to the VLAN associated with the MA. The VLAN associated with the MA is configured in MA Component Configuration Mode using vid. The MEP serves as the logical boundary between devices operating at different domain levels. MEPs are uniquely identified by an integer value that is unique within the MA it belongs to.
Use this command to access the configuration mode for the specified MEP.
The “no” form of this command deletes a MEP configuration.
This example enters configuration mode for the myMA1 MEP 1000:
System(rw-config)->cfm md string-name myMD1 System(su-config-cfm-md.1)->ma string-name myMA1 System(su-config-cfm-ma.1)->mep 1000 System(su-config-cfm-mep.1000)->
Print
this page
Email this topic
Feedback
