Use this command to configure path monitoring.
| hop-count count | The number of hops per path to track. Possible values are 0–8 hops. The default value is one hop. |
| path-count count | The number of ECMP paths to track. Possible values are 0 and 1–4 paths. The default value is zero paths. |
Any parameter not specified remains at its current value.
Configuration IP SLA entry mode.
The monitor command applies only to IP SLA echo entries.
Use the no form of the command to reset the hop-count and path-count parameters to their default values.
This example shows the hop count set to 8 hops and the path count set to 2 paths.
System(su-config)->sla entry 8 echo System(su-config-sla)->monitor hop-count 8 path-count 2
Print
this page
Email this topic
Feedback
