Use this command to set the OAM Unidirectional Link Detection (ULD) mode for the specified port.
| port-string | Specifies the port(s) to configure for ULD mode. For a detailed description of possible port-string values, refer to Port String Syntax Used in the CLI in the S-, K-, and 7100 Series Configuration Guide. |
| disable | standard | fast | Sets the ULD mode for the specified port:
ULD is disabled by default on all ports.
All command modes.
If ULD is disabled, no attempt is made to detect unidirectional operation on the link. ULD supports two modes for the detection of a unidirectional link:
The configured ULD action can be to both disable the port and send a Syslog message or to only send a Syslog message. The ULD action defaults to only sending the Syslog message.
OAM ULD requires that both link peers are configured for active OAM mode, set using set port oam mode. To prevent ULD mis-configuration, the OAM peer disregards the configured OAM mode and operates as an active peer, if ULD is configured for either standard or fast mode.
This example shows how to set the OAM ULD mode to fast for port ge.1.2:
System(rw)->set port oam ge.1.2 uld mode fast
Print
this page
Email this topic
Feedback
