Use this command to reset logging default values.
| facility | (Optional) Resets the default facility name to local4. |
| severity | (Optional) Resets the default logging severity level to 6 (notifications of significant conditions). |
| port | (Optional) Resets the default UDP port the client uses to send to the server to 514. |
All command modes.
If C2 security mode is enabled, You can not clear a local logging configuration while in Read-Write user mode.
This example shows how to reset the Syslog default severity level to 6:
System(rw)->clear logging default severity
Print
this page
Email this topic
Feedback
