Use this command to reset the port jumbo MTU size or dynamic jumbo MTU state to default values on one or more ports.
| dynamic | (Optional) Specifies that the dynamic jumbo MTU state should be reset to the default value of disable. |
| port-string | Specifies the port(s) on which the maximum jumbo MTU size is set or dynamic MTU is enabled or disabled. |
If dynamic is not specified, the jumbo MTU size configuration is cleared.
All command modes.
This example shows how to clear the jumbo MTU size configuration for port tg.1.5:
System(rw)->clear port jumbo mtu tg.1.5
Print
this page
Email this topic
Feedback
