Use this command to configure a range of virtual server IPv4 or IPv6 addresses.
| start-address end-address | Specifies a start and an end IP address that defines a range of virtual servers. |
| tcp | udp | Specifies TCP or UDP as the protocol used by the virtual server. |
| port | Specifies a TCP or UDP port number (0 through 65535) or port name to be used by this virtual server. Specifying 0 indicates all ports can be used by this virtual server, and should be used only with SIP sticky session persistence configuration. The following port name keywords may be used: ftp — File Transfer Protocol, port 21 (IPv4 only) telnet — Telnet, port 23 www — World Wide Web, port 80 all — All protocol ports |
| service service-name | (Optional) Specifies the service to be accessed through this virtual server IP address. When TCP has been specified as the protocol, service-name should be ftp. When UDP has been specified as the protocol, service name should be tftp. |
| all-vrfs | (Optional) Specifies that this VRF will handle SLB services for all VRFs for this router. |
Configuration command, SLB Virtual Server Configuration mode.
Use this command to configure a virtual IP address range, IP protocol, and UDP/TCP Port. Optionally specify a service type if the configured port is not the service‘s default.
Use the all-vrfs parameter to configure this VRF router to handle SLB services for all VRFs on this system.
This example shows how to set the an IP address range and TCP port for the “virtual-http” virtual server:
System(rw-config)->ip slb vserver virtual-http System(rw-config-slb-vserver)->serverfarm myproductHTTP System(rw-config-slb-vserver)->virtual-range 10.1.4.5 10.1.4.10 tcp www
This example shows how to set the an IPv6 address range and UDP port for the “virtual-http66” virtual server and for this virtual server to handle SLB services for all VRFs on this router:
System(rw-config)->ipv6 slb vserver virtual-http66 System(rw-config-slb-vserver)->serverfarm myproductHTTP66 System(rw-config-slb-vserver)->virtual-range 2001:11ac:fd34::5 2001:11ac:fd34::10 udp tftp all-vrfs
This example shows how to set the IP address range from 10.21.141.100 through 10.21.141.105 and TCP port for the “WWW” virtual server, and for this virtual server to to handle SLB services for all VRFs on this router:
System(su)->router Services System(su-Services)->configure System(su-Services-config)->ip slb vserver WWW System(su-Services-config-slb-vserver)->virtual 10.21.141.100 10.21.141.105 tcp www all-vrfs
Print
this page
Email this topic
Feedback
