Use this command to reset an option module CPU.
| mod.nemcpu | Resets the CPU on an option module, where mod specifies the module in which the option module is installed and nemcpu specifies the location of the option module. Currently, this value can only be 1. |
None.
All command modes.
This example shows how to reset an option module installed on the module in slot 4.
System(rw)->reset nemcpu 4.1 This command will reset NEM CPU 4.1. Do you want to continue (y/n) [n]? y Resetting NEM CPU 4.1 ...
Print
this page
Email this topic
Feedback
