Use this command to specify the OSPF metric type when redistributing a source packet matched by this route-map.
type-1 | type-2 | Specifies the OSPF metric type when redistributing a source packet by this route-map. Valid values: type-1 or type-2. Default Value: None. |
None.
Route-map configuration.
The “no” form of this command deletes this metric type set clause.
This example shows how to set the OSPF metric type to type-2 when redistributing source packets matched in the rm5 route-map:
System(rw-config)->route-map redistribution rm5 System(rw-config-route-map)->set metric-type type-2 System(rw-config-route-map)->
