Use this command to decrement the existing cost when redistributing a source packet matched by this route-map.
| cost | Specifies the amount to decrement the existing cost when redistributing a source packet matched by this route-map. Valid values: 1 - 4294967295. Default Value: None. |
None.
Route-map configuration.
The “no” form of this command deletes this metric decrement set clause.
This example shows how to decrement the route cost by 50 when redistributing source packets matched in the rm5 route-map:
System(rw-config)->route-map redistribution rm5 System(rw-config-route-map)->set metric decrement 50 System(rw-config-route-map)->
Print
this page
Email this topic
Feedback
