Use this command to reset the PFC state and counters for the specified port and priority.
| port-string | Specifies the port to reset the PFC setting to the default value of disabled. |
| priority | Specifies the priority to reset the PFC setting to the default value of disabled. |
| all | Specifies that all state and counters are cleared. |
| indications | Specifies that all indications counters are cleared. |
| requests | Specifies that all requests counters are cleared. |
PFC is disabled on all ports and priorities by default.
All command modes.
This example resets the PFC setting for all priority 5 counters on port tg.1.2 to the default value of disabled:
System(rw)->clear dcb pfc all tg.1.2 5
Print
this page
Email this topic
Feedback
