Creates or deletes a key chain used globally for RIP authentication.
| name | Specifies a name for the key chain. |
None.
Configuration command, Global configuration.
This command places you in key chain configuration command mode.
The “no” form of this command deletes the specified key chain.
This example shows how to create a RIP authentication key chain called “md5key”:
System(rw-config)->key chain md5key System(rw-config-keychain)->
Print
this page
Email this topic
Feedback
