Use this command to display the MEP‘s remote MEP configuration information.
| md | Specifies an MD context. |
| ma | Specifies an MA context. |
| mep | Specifies a maintenance end-point context. |
| string-name name | Specifies the MD or MA string name of the of the remote MEP to display. Valid values are up to 43 printable characters. |
| dns-like-name dns-name | Specifies the MD DNS like maintenance domain string name of the remote MEP to display. Valid values are up to 43 printable characters. |
| mac-int-name mac-name | Specifies the MD MAC address formatted string name of the remote MEP to display. A valid value is a MAC address formatted string plus an integer index ID value separated by a period (.) in the format xx-xx-xx-xx-xx-xx.ID or xx:xx:xx:xx:xx:xx.ID, where x is a hex value and the ID range is 0 - 65535. |
| no-name | Specifies the NULL string named MD of the remote MEP to display. |
| index index | Specifies the MD index value or the MA index of the remote MEP to display. |
| vid-name vlan | Specifies the MA VLAN ID name of the remote MEP to display. |
| id-name id | Specifies the MA ID name for the end-point of the remote end-point to display. |
| index index | Specifies the MA index value of the remote MEP to display. |
| mep-id mep-id | (Optional) Specify a maintenance end-point or its remote end-point. |
| -verbose | (Optional) A detailed level of maintenance remote end-point configuration information will display. |
All command modes.
This example displays the remote-end-point configuration information for the MA index 1, MEP 59, for the myMD1 MD:
System(rw)->show cfm md string-name myMD1 ma index 1 mep mep-id 59 remote-mep
MD Name: myMD1
MA Name: myMA1
MEP ID : 59
Remote RMep RMep RMep RDI
MepId State MAC Active Set
57 Failed 00-11-88-fd-93-4e True False
System(rw)->
This example displays the verbose level remote MEP configuration information for the MA index 1, MEP 59, for the myMD1 MD:
System(rw)->show cfm md string-name myMD1 ma index 1 mep 59 remote-mep -verbose
MD Name: myMD1
MA Name: myMA1
MEP ID : 59
RMEP ID 57
State : Failed
MAC Address : 00-11-88-fd-93-4e
Active : True
RDI bit set : False
OK Time (centiseconds) : 41601115
Port Status TLV : Up
Interface Status TLV : Up
SenderID TLV : None
System(rw)->
show cfm md ma mep remote-mep Output Display provides an explanation of the command output.
| Output... | What it displays... |
| MD Name | The name of the MD to which the MEP belongs. |
| MA Name | The name of the MA to which the MEP belongs. |
| MEP ID | The maintenance end-point ID. |
| Remote MEP ID or RMEP ID | The Remote maintenance end-point ID. |
| RMEP State or State | The administrative state of the remote MEP. |
| RMEP MAC or MAC Address | The MAC address of the remote MEP. |
| Active | The MEP configuration status: True (enabled) or False (not enabled). |
| RDI bit set | State of the RDI bit. True: RDI bit is set. False: RDI bit is not set. |
| OK time (centiseconds) | The system time the remote MEP became active. |
| Port Status TLV | Status of the physical port the remote MEP resides on. |
| Interface Status TLV | Status of the remote MEP. |
| SenderID TLV | ID permission setting for the content sent in the SenderID TLV by the remote MEP. |
Print
this page
Email this topic
Feedback
