Use this command to display compatibility mode configuration information and capabilities on an S-Series device.
| chassis-index chassis-index | (Optional) Specifies the chassis index. Valid values are 1 - 2. Default value is 1. A chassis index of 2 can occur in a virtual switch bonding (VSB) context. |
| capabilities | (Optional) Displays the compatibility mode to which each installed module in the system can be set. |
All command modes.
This example displays compatibility settings for a system that is administratively set to auto and is operationally in v1 compatibility mode:
System(rw)->show chassis compatibility-mode Chassis Index: 1 Current Fabric Compatibility Admin Mode: auto
Current Fabric Compatibility Oper Mode: v1
This example displays compatibility settings for a chassis index 2 system that is administratively set to v2 and is operationally in v2 compatibility mode:
System(rw)->set chassis compatibility-mode v2 chassis-index 2 System(rw)->show chassis compatibility-mode chassis-index 2 Chassis Index: 2 Current Fabric Compatibility Admin Mode: v2 Current Fabric Compatibility Oper Mode: v2
Print
this page
Email this topic
Feedback
