Use this command to reset auto-tracking state to the default value globally or on the specified port.
| all | Resets auto-tracking state globally on the switch to the default value of disabled. |
| port port-string | Specifies the port to reset auto-tracking configuration to the default value of disabled. |
None.
All command modes.
This example shows how to disable auto-tracking globally on the switch:
System(rw)->clear auto-tracking all
This example shows how to disable auto-tracking on port tg.1.1:
System(rw)->clear auto-tracking port tg.1.1
Print
this page
Email this topic
Feedback
