This command sets the amount of time between attempts to reestablish a connection to configured peers that are currently no longer available.
| ip-address | Specifies a BGP peer as a valid IPv4 address in dotted-quad format or as a valid IPv6 address in colon-separated format. |
| interval | Specifies the interval in seconds between attempts to reestablish a connection to configured peers that are no longer available. Valid values are 1 - 65535 seconds. The default value is 120 seconds. |
None.
BGP Router Configuration.
The no neighbor connect-retry-interval command resets the BGP connect-retry-interval to the default value of 120 seconds.
The following example sets the BGP connect-retry-interval for neighbor 9.1.2.1 to 125 seconds:
System(su-config)->router bgp 65151 System(su-config-bgp)->bgp router-id 159.1.1.9 System(su-config-bgp)->neighbor 9.1.2.1 connect-retry-interval 125 System(su-config-bgp)->
Print
this page
Email this topic
Feedback
