Use this command to enter IP SLA entry configuration mode. This command allows you to create or modify an IP SLA entry.
| entry | The number of the IP SLA entry you want to create or modify. Possible values are 1–8. |
| echo | The IP SLA entry type. An echo entry measures round-trip delay, packet loss, and packet ordering. |
None.
Configuration command.
You must specify echo.
Use the exit command to exit IP SLA entry configuration mode.
This example shows how to enter the configuration mode for IP SLA entry 8:
System(su-config)->sla entry 8 echo System(su-config-sla)->
Print
this page
Email this topic
Feedback
