Use this command to set the current setting for the Management Authentication Notification access types to the default setting of enabled.
None.
None.
All command modes.
Ensure that SNMP is correctly configured on the module in order to send these notifications.
This example displays the state of Management Authentication Notification access types prior to using the clear command, then displays the same information after using the clear command:
System(su)->show mgmt-auth-notify Management Type Status --------------- -------- console enabled ssh disabled telnet enabled web disabled System(su)->clear mgmt-auth-notify System(su)->show mgmt-auth-notify Management Type Status --------------- -------- console enabled ssh enabled telnet enabled web enabled
Print
this page
Email this topic
Feedback
