Use this command to delete a static IGMP entry, or to remove one or more ports from an existing entry.
| group | Specifies a group IP address for the entry. |
| vlan-list | Specifies the VLAN(s) on which to configure the entry. |
| modify | (Optional) Removes ports from an existing entry. |
| include-ports | (Optional) Port or range of ports in the include-ports list to be removed from this entry. |
| exclude-ports | (Optional) Port or range of ports in the exclude-ports list to be removed from this entry. |
If the modify option is not specified, all configuration for this entry is removed.
If the include-ports option is not specified, all members of the include-ports list are removed for this option.
If the exclude-ports option is not specified, all members of the exclude-ports list are removed for this option.
All command modes.
You must include the modify option when removing a part of the entry configuration using the include-ports or exclude-ports option.
This example shows how to remove port tg.1.5 from the IGMP group at 10.10.50.1 (VLAN 100) leaving the remaining configuration unchanged:
System(rw)->show igmp static -------------------------------------------------------------------------------- Multicast Group Address = 10.10.50.1 Vlan Id = 100 Source IP Address = Any Include List = tg.1.1-5 Exclude List = tg.1.6-10 System(rw)->clear igmp static 10.10.50.1 100 modify include-ports tg.1.5 System(rw)->show igmp static -------------------------------------------------------------------------------- Multicast Group Address = 10.10.50.1 Vlan Id = 100 Source IP Address = Any Include List = tg.1.1-4 Exclude List = tg.1.6-10 System(rw)->
This example shows how to remove the static IGMP entry for IGMP group at 10.10.50.1 on VLAN 100:
System(rw)->clear igmp static group 10.10.50.1 vlan-list 100
Print
this page
Email this topic
Feedback
