Use this command to display the system‘s hardware configuration.
None.
None.
All command modes.
The following S-Series SSA example shows a portion of the information displayed with the show system hardware command.
Depending on the hardware configuration of your S- K- and 7100-Series system, your output will vary from the example shown.System(su)->show system hardware
CHASSIS HARDWARE INFORMATION
Chassis Type: S-Series Standalone (SSA)
Chassis Serial Number: 094454536352
Chassis Power Supply 1: Installed & Operating, AC High Power, Not Redundant
Chassis Power Supply 2: Not Installed
Chassis Fan 1: Installed & Operating
Chassis Fan 2: Installed & Operating
Chassis Fan 3: Installed & Operating
Chassis Fan 4: Installed & Operating
Chassis Fan 5: Installed & Operating
Chassis Fan 6: Installed & Operating
Chassis Fan 7: Installed & Operating
Chassis Fan 8: Installed & Operating
Chassis Fan 9: Installed & Operating
Chassis Fan 10: Installed & Operating
Chassis Fan 11: Installed & Operating
Chassis Fan 12: Installed & Operating
Chassis Fan 13: Installed & Operating
PoE Power Supply 1: Installed & Operating
PoE Power Supply 2: Not Installed
SLOT HARDWARE INFORMATION
SLOT 1
Model: SSA-T4068-0252
Part Number: 9404332
Vendor ID: 1
Base MAC Address: 00-1F-45-5B-F5-CF
MAC Address Count: 54
Hardware Version: 1
Firmware Version: 07.11.01.0011.daveh4BFD5B25
BootCode Version: 01.00.21x
BootPROM Version: 01.01.05
CPU Version: 28674 (PPC 750GX)
SDRAM: 1024 MB
NVRAM: 32 KB
Flash System: 1024 MB
/flash0 free space: 37 MB
/flash1 free space: 62 MB
/flash2 free space: 803 MB
Temperature:
LM75: 33.500 C
Dip Switch Bank 1 2 3 4 5 6 7 8
Position: OFF OFF OFF OFF OFF OFF OFF OFF
HOST CHIP:
Type: FPGA
Revision: 839 (0x347)
FABRIC ACCESS PROC CHIP:
FAP CHIP [0]: FAP21V Revision A
FAP CHIP [2]: FAP21V Revision A
FABRIC ELEMENT CHIP:
FEs: Not present
PLD CHIP:
Revision: 3 (0x3)
NIM[0]:
Model: 48 Port 10/100/1000 RJ45, 4X, Quad-Wide Bottom, PoE+ Capable
Board Revision: 5 (0x5)
PLD Revision: 5 (0x5)
FRU: no
PoE[0]:
Software Revision: 04.00.01.02
Device Id: 0xe103
SWITCH CHIP[0]:
Type: ASIC
Revision: 0 (0x0)
System(su)->
Print
this page
Email this topic
Feedback
